ford00 Posted January 31, 2008 Share Posted January 31, 2008 I have a 1990 Lexus LS 400 I want to known where is the sign light flasher at and what do it look like. And how to replace tmy antenna and radio to a dvd player. Quote Link to comment Share on other sites More sharing options...
ford00 Posted February 4, 2008 Author Share Posted February 4, 2008 I have a 1990 Lexus LS 400 I want to know where is the sign light flasher at and what do it look like. And how to replace my antenna and radio to a dvd player. You mean know one have and answer. Quote Link to comment Share on other sites More sharing options...
Leadfoot Posted February 4, 2008 Share Posted February 4, 2008 I have attached the 2 pages from the manual for my '92, which I am sure is the same. What is the trouble you are actually having? I am assuming your turn indicators do not work, have you checked the 7.5A turn fuse? Does the hazard switch work? (It can sometimes still work even if the turn signal doesn't, so this clue will help locate the faulty component). If the fuse is OK the parts of the circuits to check are the hazard switch itself, the turn signal flasher and the turn signal switch on the steering column. Sorry, don't know about the audio questions. . Turn_Relay.pdf Quote Link to comment Share on other sites More sharing options...
ford00 Posted February 4, 2008 Author Share Posted February 4, 2008 I have attached the 2 pages from the manual for my '92, which I am sure is the same. What is the trouble you are actually having? I am assuming your turn indicators do not work, have you checked the 7.5A turn fuse? Does the hazard switch work? (It can sometimes still work even if the turn signal doesn't, so this clue will help locate the faulty component). If the fuse is OK the parts of the circuits to check are the hazard switch itself, the turn signal flasher and the turn signal switch on the steering column. Sorry, don't know about the audio questions. . The indicator don't work .The Hazard light does not work .The Fuse 7.5 A is not broke. The question I have is My Sign Light are not working . And My Light was lighting up . But the sign light was not working but now it is not light up inside and not giving sign at all . Quote Link to comment Share on other sites More sharing options...
