91 LS400 Posted January 30, 2008 Share Posted January 30, 2008 Hi, i'm new here so sorry if this is made in the wrong area.. I have a '91 LS400 that was givin' to me as my first car years ago, about early last year my car died on me and i'm no mechanic i know very little about cars from the mechanic side. I have a friend who is real good with them and he found out that my power steering hose had a leak and he called around and a dealership told hiim that that particular model/year had a problem with the power steering hose leaking into the alternator. I had the alternator replaced and a few weeks ago the same thing happened. I just got a new alternator but i'm having trouble finding a power steering hose. Does anybody know where i can find one or a way i can repair the old one and perhaps how i can prevent this from happening again? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
TA in KC Posted January 30, 2008 Share Posted January 30, 2008 Hi, i'm new here so sorry if this is made in the wrong area.. I have a '91 LS400 that was givin' to me as my first car years ago, about early last year my car died on me and i'm no mechanic i know very little about cars from the mechanic side. I have a friend who is real good with them and he found out that my power steering hose had a leak and he called around and a dealership told hiim that that particular model/year had a problem with the power steering hose leaking into the alternator. I had the alternator replaced and a few weeks ago the same thing happened. I just got a new alternator but i'm having trouble finding a power steering hose. Does anybody know where i can find one or a way i can repair the old one and perhaps how i can prevent this from happening again? Thanks for any help. There are several "hoses" on the pump. Which are you referring to? The high-pressure line, which many people, including myself, frequently refer to as a hose. It is actually a metal tube so that is probably not a very good term to use as it confuses people. Those cost around $150. If you are referring to the actual rubber hoses, like the return hose, you can buy those by the foot at most auto parts stores. The cost is usually about $1.50 per foot. Quote Link to comment Share on other sites More sharing options...
marlon08901 Posted January 30, 2008 Share Posted January 30, 2008 Hi, i'm new here so sorry if this is made in the wrong area.. I have a '91 LS400 that was givin' to me as my first car years ago, about early last year my car died on me and i'm no mechanic i know very little about cars from the mechanic side. I have a friend who is real good with them and he found out that my power steering hose had a leak and he called around and a dealership told hiim that that particular model/year had a problem with the power steering hose leaking into the alternator. I had the alternator replaced and a few weeks ago the same thing happened. I just got a new alternator but i'm having trouble finding a power steering hose. Does anybody know where i can find one or a way i can repair the old one and perhaps how i can prevent this from happening again? Thanks for any help. There are several "hoses" on the pump. Which are you referring to? The high-pressure line, which many people, including myself, frequently refer to as a hose. It is actually a metal tube so that is probably not a very good term to use as it confuses people. Those cost around $150. If you are referring to the actual rubber hoses, like the return hose, you can buy those by the foot at most auto parts stores. The cost is usually about $1.50 per foot. Are you sure that the leak is coming from a "hose" and/or even a high pressure line and that..that is all you need to replace?...I ask this because I think that the most common leaks are from the power steering pump "seal".....you can find many posts about his particular problem...I would really suggest for you to just do a little more research before you spend your money. Quote Link to comment Share on other sites More sharing options...
91 LS400 Posted January 30, 2008 Author Share Posted January 30, 2008 Hey, thanks to both of you for responding, i'll find out more and let my friend know and find out, but i believe it was the pressure hose that thomas referred too. Soon as i find out more info i'll post back, and in case it is the pressure hose, do you know of a reliable website that sells it? Quote Link to comment Share on other sites More sharing options...
JIBBBY Posted January 31, 2008 Share Posted January 31, 2008 Your powersteering leak probably took out the alternator...They have a tendancy to leak right onto the alternator... Remove the leaking hose...If it a standard rubber hose with no special fitting on the ends just take the hose into any autoparts store and they will cut you one to fit...Very cheap and effective...If it a pressure hose with special fitting then call around or go to the dealer and get reamed.... Good luck.. Quote Link to comment Share on other sites More sharing options...
91 LS400 Posted January 31, 2008 Author Share Posted January 31, 2008 So, i talked to my friend and he said it's the pressure hose for sure. Quote Link to comment Share on other sites More sharing options...
TA in KC Posted January 31, 2008 Share Posted January 31, 2008 So, i talked to my friend and he said it's the pressure hose for sure. The pressure hose costs around $400 at the dealer. They are hard to find online. The best place to look for a cheaper one is probably local auto recycler. Quote Link to comment Share on other sites More sharing options...
CUMan Posted February 1, 2008 Share Posted February 1, 2008 The high pressure hose for a 91 LS is $361.34 at Park Place Lexus (Plano, Texas) when purchased online. Quote Link to comment Share on other sites More sharing options...
