Es300 '96 Po135
Hi Folks...
Need some help.
Getting P0135. This indicates is a faulty O2 sensor, specifically, Heater Circuit Malfuntion.
The O2 sensor in question is located at Bank 1 Sensor 1.
Here's the question.
My Lexus manual says it's the sensor located just behind the radiator in the exhaust manifold. (Super easy to get at.)
Others say... This is the O2 sensor that is between the firewall and the engine. (Tough to get at.)
I changed the one by the radiator with a "generic" sensor and after about 25 miles the CEL came back on.
Do you think I changed the correct sensor and if so...are these generic sensors just 'junk?'
Thanks....
Hi Folks...
Need some help.
Thanks....
You changed the wrong one..
Bank 1=the bank 1 cylinder is on
Bank 2=the bank 2 cylinder is on
Regards,
lexushead
ASE/L1 Master
Toyota Lexus Factory Certified Master
www.toyautoservice.com
Hi Folks...
Need some help.
Thanks....
You changed the wrong one..And you should use OEM parts for this condition...
Regards,
lexushead
ASE/L1 Master
