Check Engine Light
I have a 93 sc300. When i start my car it almost die's instantly. The only why i can keep it going is if i hit the gas pedal. The check engine light is also showing. I was hoping someone can tell me how to pull codes without a ob1 scan tool.
All you have to do is short out a couple of pins on the data link connector(1- on top of engine [rectanglular]; 2 - front/left floor [round].
Jump E1 with TE1 to get codes.
-With jumper installed; crank engine. you must count the 'CHECK ENGINE' light as it flashes.
-First series= first digit; a short pause. Second series = second digit. then a longer pause.
then; the next code and so on. I think once it goes through the list it repeats.
Jump E1 with TE2 to clear code.
-With jumper installed; crank engine and the 'CHECK ENGINE' light will flash continuosly.
hope it helps.
