Owner Manual Ls430 Model 2001
naughty77
hi folks
i bought a used LS430 2001 model from DUBAI, american exported and america specs.
i do not have the owner manual and i need one. i tried to register at the lexsus owner but failed because no address or me in the US. i also tried to reigster at the typta tech info where i can hire dcuments at 10 dollar per day abnd i failed after trying many address.
can some one give me LS430 2001 owner model.
i have also a problem, the car takes long time to start (delay start). i chnaged battery, plus and same problem. i have seen 2 electcian and then are not sure what is the problem is , they gave me options, fuel pump, fuel filter, he thinks starter is okay, but not conclusive and i do not want them to try dismanlt and learn as they go. the dealer in this country (Oman, is my country) does not service or repair the non-gulf specs for stupid reasons. i can travel to next country Dubai but long way and have to leave work few days which is a headache.
any one has experience with this?
can i use the car, despite the long time to start, like 5 cranks before it starts?
can some one give me owner manual?
many thanks
hi guys
any one helping me please?
thanks
hi folks
many thanks
Check and clean your battery terminals maybe replace the negative, make sure you have your battery tested. Replace your fuel filter it will never hurt to do so. If the problem continues you will need to see if you can test the starter. Use 93 octane plus gas in it. Make sure you have the recommended engine oil in the car for the temperatures in your country, and clean all your ignition plugs with electrical car parts cleaner. Last make sure you stay on the ignition swicth the time is necessary sometimes we baby this cars too much and retract the key before we give time to the engine to start.
My two cents.
CPR
