greggebhardt Posted November 27, 2003 Share Posted November 27, 2003 Just purchased 2004 LX470 2 days ago. Have 3 garage doors of which I have programmed two with no problem to use the Lexus Homelink. The third door has the "rolling code" thisng but I have followed the instructions and can not get it to operate this particular unit. The Opener is the Overhead Door Signature series. I hit the l;earn button on the opener and have tried two pushed of the button with an additional push as the manual indicates. I also went to the OverHead door website and they say push the learning button and then the homelimk button 3 times, still no go. Anyone got any suggestions? Quote Link to comment Share on other sites More sharing options...
Thi Posted December 2, 2003 Share Posted December 2, 2003 After pressing the "learn" button, you have 30 seconds to press the designated button in your car. Press the button in your car for 2 seconds then release. You may have to repeat the sequence press, hold, and release the button for 3 times (don't press the "learn" button again for the subsequence cycles). After programming the button, try to press the button and hold it down and see if your garage openner works. You can find some more info at http://www.homelink.com/program/rolling.html Thi Quote Link to comment Share on other sites More sharing options...
khamel Posted December 11, 2003 Share Posted December 11, 2003 After pressing the "learn" button, you have 30 seconds to press the designated button in your car. Press the button in your car for 2 seconds then release. You may have to repeat the sequence press, hold, and release the button for 3 times (don't press the "learn" button again for the subsequence cycles). After programming the button, try to press the button and hold it down and see if your garage openner works. You can find some more info at http://www.homelink.com/program/rolling.htmlThi The above worked for me. I did go to the URL http://www.homelink.com/program/programming.tml to get the detailed info, but the trick is to attempt to program it as normal, it won't work, press the "learn" button on the garage door opener, you have 30 seconds to press and hold the homelink button that is not working for 2 seconds and then release. What happened for me is after the 1st 2 second cycle, the light on my garage door opener flashed and the homelink button now worked. I did not need to repeat the 2 second hold/release cycle a 2nd time. Cheers, --Ken-- Quote Link to comment Share on other sites More sharing options...
greggebhardt Posted December 11, 2003 Author Share Posted December 11, 2003 Thanks Ken, I will give it another try and let you know how it works. ;) Quote Link to comment Share on other sites More sharing options...
460Phil Posted May 13, 2009 Share Posted May 13, 2009 Like everyone here, I was totally frustrated with this process. I finally reached a human at HomeLink and after describing the situation he asked if I was using a Genie mini-remote door opener, which indeed I was. He asked if I was using the large button to train the in-car unit, which I was. It seems you cannot use the large button, you must use one of the small buttons to the left of the large one to train your unit. Once I used the small button it worked perfectly and connected through the Learn program on the first attempt, it took less than 5 minutes. I emailed HomeLink suggesting they add this info to their FAQ or Troubleshooting website. This could have saved me 2 hours of wasted, very frustrating, time. But, I am a happy camper now. Quote Link to comment Share on other sites More sharing options...
msscha01 Posted July 29, 2010 Share Posted July 29, 2010 After talking with HomeLink, I was instructed to repeatedly press the garage door opener remote(not the car Homelink button) that I was using instead of holding it down while still holding the HomeLink button during the training mode. This worked after about 60 seconds (and many many up-and-downs from the garage door). I still had to hit the "Learn" button on the garage door opener, and then press the HomeLink button three times within 30 seconds of hitting "Learn." Also, I was using a "dual frequency" Genie remote, and I had to switch the frequency on the remote to work with HomeLink in the car. This worked for me. Quote Link to comment Share on other sites More sharing options...
Rob In St. Petersburg FL Posted January 2, 2021 Share Posted January 2, 2021 I had the same problem with my Lexus 2006 LX470. I have the "Overhead Door" door opener. Finally after using the steps listed on this website, my Homelink remote works. https://www.ohd.com/programming-homelink Quote Link to comment Share on other sites More sharing options...
fred99 Posted August 3 Share Posted August 3 I have a 2024 lexus nx350. I have paired the car for my garage door. What is the process if I want to pair my car to our community gate? I have a different remote that operates the gate but am hesitant to start with pressing buttons 1 and 3 for fear of erasing the link for my garage door. Quote Link to comment Share on other sites More sharing options...
