Check Engine Light On. P0505 - Idle Control System Malfunction
chmura
I have a 2002 RX AWD 3.0 V6.
I got a check engine light on. I immediately check it and I got the following:
Does this code pertain to the Idle Air Control Valve and needs cleaning/replacing?
I want to make sure this code is the IACV before I clean/replace it.
MY 2001 RX300 KEEPS STALLING OUT- IS THAT IDLE AIR CONTROL PROBLEM.
DOES ANYONE KNOW WHERE TO GET GOOD TUNEUP IN SO FLORIDA?
THANKS
Yes that is your Idle Air Control Valve. Get it cleaned or replace it.
Thanks for the thread jack. :chairshot:
