has anyone else have this problem? it seem that every morning when i start the rx up i get this loud clunking noise
Wut is ICE? its been like this for about 2wks now made an appt to get it check out hope its nothing serious,i just wondering if anyone else have this problem the sounds coming somewere near the tranny an when it starts the rx starts to jolt
ICE = Internal Combustion Engine
Wut is ICE?
:rolleyes:
You must be new to "Hybridology." Reminds me of when I first started looking at hybrid message boards and encountered that mysterious acronym.
"ICE" stands for Internal Combustion Engine. You'll see it used all over these forums.
As for your noise problem, I can't help you out. Mine doesn't make any "loud clunking noise" when starting up. Do you hear it INSIDE the vehicle as well?
Do you depress the brake when you start up the car? If so, it might be your brakes. I've had the same problem in cold weather. The dealership tells me it's normal to have a clunking sound when braking hard. I don't know if I buy that, but, they've told me that three times, now. So, when I brake hard, I hear a clunking sound (from the inside of the car). Don't know if it's the same as your problem.
well im only getting a noise only when i start the car the first 2second that the rx is on u can here a loud clunk an now its been like this for almost a month an driving me bonkers . i took it to the dealers an they said it was normal ,bulls**t theres definaly something wrong
