GRR Posted January 11, 2008 Share Posted January 11, 2008 97 LS400 - key will not turn past accessory, when attempting to turn off ignition, therefore it will not come out. I am able to crank car up again, back up, or move forward, turn the steering wheel several times, then it usually turns all the way off and key will come out. It has been doing this every couple of months for about 3 years. When I checked on having it repaired, it was going to be upwards of $1,500, new steering column, ignition switch, etc. Any suggestions on what could be causing this problem. 133,000 miles, no other problems. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted January 11, 2008 Share Posted January 11, 2008 Since the key will come out with some manipulation as you described, have you tried the telescoping/tilting features of the steering wheel to see if there's a position that will allow you to remove the key? If you find one, then to reset the wheel to your driving position, you simply press your preset memory 1 button. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted January 11, 2008 Share Posted January 11, 2008 PS: The position that allows you to remove the key would be preset 2. Quote Link to comment Share on other sites More sharing options...
GRR Posted January 11, 2008 Author Share Posted January 11, 2008 PS: The position that allows you to remove the key would be preset 2. Haven't tried that, but will after I drive home today. Thanks a bunch! Will let you know if it works. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted January 12, 2008 Share Posted January 12, 2008 Just curious, how did you ever come up with the routine that releases your key? Was it a suggestion by you mechanic? It does however sound like an ignition switch. Good luck. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 12, 2008 Share Posted January 12, 2008 Spray some pb blaster inside the cylinder as the tumbler may be sticking but it may be a problem with the park indicator malfunctioning telling the lock the car is not in park. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted January 12, 2008 Share Posted January 12, 2008 Yes the park/neutral switch may be intermittent. Next time you can't remove your key, try jiggling the shifter to see if it releases. To check the tumblers, next time you can remove the key, try inserting/removing it several times. Check whether there's any difference in the resistance when sliding the key. Quote Link to comment Share on other sites More sharing options...
blake918 Posted January 30, 2008 Share Posted January 30, 2008 97 LS400 - key will not turn past accessory, when attempting to turn off ignition, therefore it will not come out. I am able to crank car up again, back up, or move forward, turn the steering wheel several times, then it usually turns all the way off and key will come out. It has been doing this every couple of months for about 3 years. When I checked on having it repaired, it was going to be upwards of $1,500, new steering column, ignition switch, etc. Any suggestions on what could be causing this problem. 133,000 miles, no other problems.My key got stuck yesterday afternoon. I had to disconnect the battery to get my key out. Then, I sprayed some silicone lubricant in to the ignition, cylced the key a few times, and she's good as new now! Quote Link to comment Share on other sites More sharing options...
