ivrule Posted November 26, 2003 Share Posted November 26, 2003 Has anyone done oil pan gasket replacement before? Mine (92) is leaking. Is it difficult? Quote Link to comment Share on other sites More sharing options...
dmccombs Posted November 26, 2003 Share Posted November 26, 2003 Hi, I just bought a 95 ES300 and it needed the oil pan gasket replaced. You can go to a Lexus or Toyota dealership to get the gasket material (tube or glue-like material) for ~$13.00. The rest is labor. The dealers quoted it as a 3 hr job. It looked easy to do if you are mechanically inclined as the gasket is easy to get to from underneath the car. Some of the 3 hr time is spent letting the gasket material set (dry). Regards, Darrell McCombs Quote Link to comment Share on other sites More sharing options...
squarehat Posted November 26, 2003 Share Posted November 26, 2003 What are the symptoms of this oil pan gasket failure? My '96 ES with 97K miles is leaking a small amount of oil each day, in a spot closer to the passenger side front wheel. I'm hoping it's not something major causing this leak. Quote Link to comment Share on other sites More sharing options...
ivrule Posted December 1, 2003 Author Share Posted December 1, 2003 Sounds more like oil pan gasket problem. I have the same problem. If you take a closer look from underneath, you see the oil leaking from the oil pan gasket. I bought the gasket and sealant last week. Need to find some time to work on it. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 1, 2003 Share Posted December 1, 2003 Don't use diy sealer to do the gasket that is a real hick way of doing things. Buy the proper gasket from toyota for a camry it is the same ,if you think you are going to be over charged at lexus.And don't listen to people telling you to add selaer to gaskets just put a thin film of oil and yiou need to scrape off any old gasket material from it as well. To remove the pan and reinstall is about 1 hour the most with the right toolsas you are also doing an oil change as well. Quote Link to comment Share on other sites More sharing options...
su24 Posted December 2, 2003 Share Posted December 2, 2003 My pan in my 92 was leaking also. All I did was take it apart, scrape off old material and apply a good amount of sealant to the proper places. Make sure to clean the mating sides of the pan and the engine block with acetone or something like that. ( I hope I'm not a hick for doing this ). As for the leak from the passenger's side - it could be coming from the timing belt area leaking off the tensioner. I had this problem. Just take off the no. 2 timing belt cover and look for where the oil is leaking from. Quote Link to comment Share on other sites More sharing options...
squarehat Posted December 2, 2003 Share Posted December 2, 2003 Hmm. The car is going in tomorrow for it's scheduled oil change, I'll have them check it out. The timing belt was changed at the 90K service, although the layout of the 94+ engines is different than the 92-93's. Quote Link to comment Share on other sites More sharing options...
ivrule Posted December 8, 2003 Author Share Posted December 8, 2003 I looked at the oil pan and found that I need to disconnect exhaust pipe and some kind of engine support. Can anybody share the information on what portion of the exhaust pipe (one or two) needs to be disconnected? Any other challenging aspects such as handing gaskets for each exhaust pipe? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 8, 2003 Share Posted December 8, 2003 can anyone list step by step procedure for it? Quote Link to comment Share on other sites More sharing options...
