toped82 Posted January 10, 2008 Share Posted January 10, 2008 I am trying to change the license plate light on the back side of my IS300. please assist me. Quote Link to comment Share on other sites More sharing options...
smooth1 Posted January 11, 2008 Share Posted January 11, 2008 Yeah, it's a little trickyer than it looks. Open the trunk and remove the liner on the trunk lid. If you look from the side of the trunk, you will see 2 bolts that hold the trim piece on the other side. Remove those. Then you'll need to loosen the trunk key lock so the trim releases. Once you have that, then you can pop the clear lense cover off and replace the lights. ( I used 6 bulb hyper white LED's, Looks great!) Then put it all back together and your done. Quote Link to comment Share on other sites More sharing options...
toped82 Posted January 14, 2008 Author Share Posted January 14, 2008 Thanks a lot guy. I'll try to do it tonite. It sounds easier than it probably is. I appreciate your help. Can I email you with more questions? if I have any? Thanks Again, Tony Yeah, it's a little trickyer than it looks. Open the trunk and remove the liner on the trunk lid. If you look from the side of the trunk, you will see 2 bolts that hold the trim piece on the other side. Remove those. Then you'll need to loosen the trunk key lock so the trim releases. Once you have that, then you can pop the clear lense cover off and replace the lights. ( I used 6 bulb hyper white LED's, Looks great!) Then put it all back together and your done. Quote Link to comment Share on other sites More sharing options...
