I just had the Arnott suspension kit installed on my 96 Ls but now theres a hi height light blinking on the dash what should I do to rid it?
If it is just the light that is bothering you, I recommend removing the bulb!
Is your car sitting high now? There should be a sensor that determines if your car has "high height" and it may need to be adjusted.
Disconnect the battery terminal for a few minutes then reconnect and start. Lights should go off.
If “Ridgerez” suggestion does not work or light returns try disconnecting the battery (both terminals) let sit a few min… then place the positive and negative together for about 15 to 20 min… this will force a reset/delete of all stored error-data in the ECU. If there is truly a problem with the height then you should consider looking over the suspension if you are not capable of finding anything then you will want to go to a professional.
Hey guys thanks I didn't set my email notifications , thanks for the info I'll try tomorrow and let you know.
