hask2004 Posted January 9, 2008 Share Posted January 9, 2008 hi every body i am a new member from midle east i have Lexus LS400 power steering problem , the power steering rack had a leak oil i had bought kit from the dealer ( orginal kit ) and fixed it surely as orginal , but now the steering is loose ( ok ) when i turn it at left, but heavy and like normal steering when i turn it to right side ! any one can help me with this problem and give me the soultion ! ( there is no sound of the power steering ) . another problem is on the break, its ok but the break Brake pedal Flexible not like a new break ! and i change the kit of master selender and make a pleading and no change in the break pedal , are lexus break normaly like this? and there is a method to make easy pleading ?! and i am sorry for long question i am wate Quote Link to comment Share on other sites More sharing options...
Bali26 Posted January 9, 2008 Share Posted January 9, 2008 Did you use correct brake fluid? Did you properly bleed the brakes? Your PS rack is not installed correctly or defective. Clean PS solenoid screen. Quote Link to comment Share on other sites More sharing options...
hask2004 Posted January 10, 2008 Author Share Posted January 10, 2008 Did you use correct brake fluid? Did you properly bleed the brakes? Your PS rack is not installed correctly or defective. Clean PS solenoid screen. yes i had used DOT3 type of oil , and about pleading , what tire shoud i make it first after master selender ? and i dont understand this " Clean PS solenoid screen. " please thanks for replay and i am wate Quote Link to comment Share on other sites More sharing options...
hask2004 Posted January 10, 2008 Author Share Posted January 10, 2008 any one help ! Quote Link to comment Share on other sites More sharing options...
Bali26 Posted January 10, 2008 Share Posted January 10, 2008 Post number 6. http://us.lexusownersclub.com/forums/index...torial&st=0 search for bleeding brake system. Quote Link to comment Share on other sites More sharing options...
hask2004 Posted January 11, 2008 Author Share Posted January 11, 2008 Post number 6. http://us.lexusownersclub.com/forums/index...torial&st=0search for bleeding brake system. thanks i will try , i see this http://www.lexls.com/tutorials/brake/bleeding.html and i bleed the according to this lesson, and i start from Rear left tire, and after that, Rear right , but when i come to the front right tire, the brake come down ! and the prasure of oil not strong! and the master selender kit is new ?! any idea for this ? :cries: Quote Link to comment Share on other sites More sharing options...
