Tire And Wheel Fit?
Going from a 16" tire to an 18" tire is quite a jump, but not impossible. Since they're factory Lexus tires, and if the bolt pattern matches, I don't see an issue, however, you want to be sure you don't need any additional changes to your axle's, i.e., rotor changes or caliper changes.
I know some after market rims require mods for clearance. Double check with Lexus, they should be able to let you know if they cross match......
