Adjusting Horizontal Angle Of Headbeam
jttegx
i installed HIDs in a 93' es300 and i was able to figure out the vertical adjustments of the head beams but how do i go about the left/right? i see a dial with teeth and a turning switch...i tried moving that using a 8mm socket wrench turning left and right but nothings moving. how do i adjust the left/right feature of the head beam?
The dial you described is the one for the horizontal movement (left/right). You may not have turned it enough to see any movement of the headlight beam, it's very gradual.
I'm curious, what HIDs did you install?
i tried adjusting this using a 8mm socket at the end. its only moving up/down
