Overheating Problems
gdave
this is very annoying my car overheats and i have changed the thermostat and my coolant levels are full ,after like 20 min of driving it will just get hot then shoot to the red zone and start to overheat, answers on why this occurs would be very helpful
thanks , dave
Gdave, a couple of questions. How long has it been overheating, have you noticed whether any of your fans are working? Any smoke from the engine area, particularly the front of the engine, and have you smelled anything? If you have none of these, you could have a blocked rad. Are you getting any heat inside the car? If you run the heater on max does your temp gage go down? Even if you haven't noticed smoke or smelled anything your water pump could be seized. If that's the case then your timing belt will be shredding as you drive and will soon fail. Check to see what condition your belt is in. If you notice any shredded teeth, you need to replace it.
Its probly been overheating for a couple of weeks up until that the car was in my garage sittin,i have no heat in the car until the car starts to overheat and once it overheats there is smoke and a very bad smell from the engine the smoke comes from the front drivers side once overheated
With the smoke and bad smell you describe, sounds like you're burning your timing belt on a seized pump or idler pulley. Your getting heat inside the car when it's starting to overheat only because of the pressure forcing coolant circulation into your heater. If it's a gen1 (90 - 94) you can drive it into a shop as long as you stay out of the red. You don't want to add head gaskets to your problems. If it breaks enroute you won't damage anything but you'll be stranded. If it's a newer model with an interference engine, tow it. Either way get it nto a shop unless you can do it yourself. Replacing a timing belt is about 9 out of 10 on the difficulty scale.
