white ls400 Posted January 3, 2008 Share Posted January 3, 2008 OK iv been told its a good idea to clean the mesh around the pick up... Would anyone be able to give me a step by step instructions how to do as i dont want to pull it apart and realise i dont know whats what. Thanx for your time Quote Link to comment Share on other sites More sharing options...
Lexuszeal Posted January 5, 2008 Share Posted January 5, 2008 This is a relatively easy procedure. Remove the rear seat and backrest. Directly in the center of the fuel tank you will see a metal plate with 8 or so small bolts. Remove this plate and this will give you access to the fuel pump. Carefully remove the fuel pump and associated parts. You will likely want to have some plastic or a tarp by this step in order to remove the fuel pump without fuel dripping everywhere inside your car. From here you will have the general idea, as you say, of what needs to be done to clean the fuel pumps pickup mesh. When I did this I simply used some extra seafoam I had around to clean the screen. But I assume you can also use water as long as you allow it to dry before reassembling the pump into the fuel tank. Good luck Quote Link to comment Share on other sites More sharing options...
