TomTA Posted December 31, 2007 Share Posted December 31, 2007 I am about to change the oil for the first time in my 92 SC400. Usually the oil sump holds about 5 quarts. Is this correct for the SC? Also what is the capacity of the differential, and which gear lube does it use? I am thinking I should change the gear lube just to be nice to the car. Quote Link to comment Share on other sites More sharing options...
Steelwheels Posted December 31, 2007 Share Posted December 31, 2007 5.1 US qts Oil change with filter change. 5w-30 Differential oil 1.43 US qts Hypoid gear oil API GL-5, above 0 degrees F: SAE-90, Below 0 degrees F: SAE-80W-90 or 80W These are from a 93 SC400 owners manual. Should be identical Good Luck on your first fluid changes. Quote Link to comment Share on other sites More sharing options...
