Rx400h Wheels Offset?
Hey I was looking to see what the stock RX 400h 18" wheels offset is?
I'm actually looking to buy a new set of rims that could make my RX handle better, anyone know what size of offsets is possible for my car?
You are going to want to go 1/2 wider and with at least a 1/4" lesser "postive offset which puts the tire farther out from the car so it won't rub (zero offset would probably be taking things too far).
thanks for the help dude! :cheers:
Looking for a new set of 20" wheels myself. I took these photos real quick while the guy was working with another customer.
thanks that helps alot, i've been looking into 20's for the RX and i've set my sights on 20x8.5" rims with a 5 x 4.5" or 5 x 114.3mm bolt pattern, the wheel has to have a +35 offset although i'm sure a +33 would work or a +37,
Tires would have to be a 255/45/20, much bigger footprint and a stiffer ride which i prefer :)
