Es300 Manual Swap
JackP
  • 7 months later...
Has anyone ever put a 5spd manual from a solara v6 or camry v6 5spd into an ES300?
Is this feasable?
you can definately put a manual into a es300 but you will have to modify alot. including buying a manual trans ecu and wiring harness clutch and brake pedal new flywheel disk and pressure plate clutch slave cylinder shifter and shifter linkage and new center console to make it look good. it'll get expensive real quick.
