2000 Ls400 Headlight Adjustment
ROBERT THOMASON
There are two vertical adjustment bolts on the back of each HID headlight housing. They stick out pretty far on my 00 LS and are hard to miss.
Both bolts are towards the bottom of the housing - one in the middle of the housing and the other at the inboard side.
I would see if it is only one side that is giving you the problem or both. If one the above fix works to align them on a wall. If both are high adjust the arm on the right rear lower control arm behind the wheel up and down to get both in the right spots.
