Temperature Control Module
x72treme
Heater stop working and isn't blowing, panel display lights up, but no ability to control settings.
Mechanic says I need to replace the temperature control module, for 1992 - sc400.
Any ideals where one can be founded? What does it look like? Will one from any other series fit?
Thanks,
gigi
Before you replace it, check the fuse for your cigarette lighter.
Is your cigarette lighter working, or not??
The same fuse controls both. You may have dropped something dowwn inside the lighter socket that blew the fuse.
Check inside the lighter socket before replacing the fuse. If there is something in there it will blow again if you do not get it out first.
Tom
I have a 92 lexus SC400. The car starts when its cold, but after it warms up, it starts up and then dies. Mechanic said its the temperature control module. Anybody familiar with this problem or have an idea or a way to solve it ?
Thanks.
Kay.
