plutnium Posted December 21, 2007 Share Posted December 21, 2007 does anyone know what error 25 is? Quote Link to comment Share on other sites More sharing options...
R.Holmes Posted December 21, 2007 Share Posted December 21, 2007 does anyone know what error 25 is? "B" Camshaft Position-Timing Over Retarded (Bank 2) Sounds like timing problem Quote Link to comment Share on other sites More sharing options...
SeanGrac Posted December 22, 2007 Share Posted December 22, 2007 does anyone know what error 25 is? It is lean or rich. I can't remember. Look through the other posts to confirm. It not camshaft. those are 12 & 13 Quote Link to comment Share on other sites More sharing options...
R.Holmes Posted December 22, 2007 Share Posted December 22, 2007 does anyone know what error 25 is? It is lean or rich. I can't remember. Look through the other posts to confirm. It not camshaft. those are 12 & 13 I apologize for my previous post. I guess I was assuming you meant the code reader code 25. You probably meant Lexus code 25. Sorry if I missled you and misinterpreted your post. Happy Hoidays anyway Quote Link to comment Share on other sites More sharing options...
gordonw Posted December 22, 2007 Share Posted December 22, 2007 Code 25 is for your ABS/TRAC system. Quote Link to comment Share on other sites More sharing options...
Lextek1 Posted December 23, 2007 Share Posted December 23, 2007 Diag Code 25 Air–Fuel Ratio Lean Malfunction Diag. 26 Air–Fuel Ratio Rich Malfunction CIRCUIT DESCRIPTION Refer to page TR–38 for the circuit description. Code No. Diagnosis Trouble Area 1*1. The conditions (a) and (B) below are detected once, then are established again after the ignition switch is turned from OFF to ON. (a) The engine is warmed up and is in a high load condition at an engine rpm higher than 1500 rpm. (B) The main oxygen sensor signal stays lean for a set period of time or longer. Harness or connector between ECU and main oxygen sensor. Main oxygen sensor. Fuel line pressure. Ignition system. Air intake system. Injector circuit. Water temp. sensor. Intake air temp. sensor. ECU 25 26 Normal Mode 2*2. When air–fuel ratio feedback compensation value feedback frequency is abnormally high during idle switch on and feedback condition. 3*3. When the difference of air–fuel ratio feedback compensation value between right and left banks is more than a certain percentage. Code 25 displayed : Deviation to lean side with the difference more than a certain percentage. Code 26 displayed : Deviation to rich side with the difference more than a certain percentage. Codes 25 and 26 displayed: Deviation to rich or lean side with the difference less than a certain percentage. Fuel line pressure. Air intake system. Injector circuit. Ignition system. Cold start injector circuit. Water temp. sensor. Intake air temp. sensor. ECU Test Quote Link to comment Share on other sites More sharing options...
Lextek1 Posted December 23, 2007 Share Posted December 23, 2007 Check for a bad or lazy main o2 sensor by reading the voltages. Check for air leaking into the intake downstream of the air flow meter. Like the vacuum hoses from the P/S pump. Just ideas! Hope this helps. Quote Link to comment Share on other sites More sharing options...
