LEXIE Posted December 15, 2007 Share Posted December 15, 2007 I have located the drier "hidden" under the driver's side headlight. Can't find removal instruction in archives I guess like most other repair projects.... do I have to disassemble the car to get it out? Lexie Quote Link to comment Share on other sites More sharing options...
GrnHrnt Posted December 15, 2007 Share Posted December 15, 2007 Jack and support driver side front. Remove tire and wheel assembly. Remove front fender liner. Remove driver side front low beam headlight. Receiver /dryer and it's fittings will be accessible. Bleed AC system pressure before removing. :) Quote Link to comment Share on other sites More sharing options...
LEXIE Posted December 16, 2007 Author Share Posted December 16, 2007 Jack and support driver side front. Remove tire and wheel assembly. Remove front fender liner. Remove driver side front low beam headlight. Receiver /dryer and it's fittings will be accessible. Bleed AC system pressure before removing. :) G'H'....thx for the brief/concise explanation. i think i can handle it from here. L Quote Link to comment Share on other sites More sharing options...
