vltjr Posted December 13, 2007 Share Posted December 13, 2007 Recently my '91 LS400 has been experiencing a tach problem that is slightly different than those that I've read about in these forums. On start-up the needle jumps to 500rpm and just stays there regardless of what the actual engine speed is. Before this problem occurred, I was having some intermittent problems with the tach just sitting at zero for a short time after starting (twenty seconds or less). Any ideas? Thanks. Quote Link to comment Share on other sites More sharing options...
Lexozz Posted December 14, 2007 Share Posted December 14, 2007 Recently my '91 LS400 has been experiencing a tach problem that is slightly different than those that I've read about in these forums. On start-up the needle jumps to 500rpm and just stays there regardless of what the actual engine speed is. Before this problem occurred, I was having some intermittent problems with the tach just sitting at zero for a short time after starting (twenty seconds or less). Any ideas?Thanks. I could only assume that the spindle or contacts are either worn or corroded. I have a similar problem when starting the engine, the tach sticks at zero until I hit the dash then it wakes up. Quote Link to comment Share on other sites More sharing options...
