EMP Posted December 10, 2007 Share Posted December 10, 2007 Alright, I know already that I have to wait until after the beep to put in my navigation instruction. I don't need to be told each time. Is there a way I can turn off Ms. Navigation and just have a beep after I push the talk button? It would certainly make entering faster. Txs Quote Link to comment Share on other sites More sharing options...
NM350 Posted December 11, 2007 Share Posted December 11, 2007 I don't have my owners manual right handy, but yes you can disable the intro. It's in (on) the set up screen. As I recall there are three pages to that selection. Again since I don't have the manual right handy I can't recall the page, but I want to say the second page. I set mine up so that there is a beep only. There are voice selection you can make that do bring back the 'voice' to ask a question or make a statement however. I don't know if you can (or even want to) turn that feature off. Quote Link to comment Share on other sites More sharing options...
sharpcolorado Posted December 11, 2007 Share Posted December 11, 2007 It is called Voice Recognition Command. Not a good name for it, since it means 'a command by your nav system to say a command. Probably a bad translation from Japanese. Menu, Setup, go to page two, and turn it off. Then you will merely hear a "chirp", rather than the voice prompt. Quote Link to comment Share on other sites More sharing options...
EMP Posted December 11, 2007 Author Share Posted December 11, 2007 It is called Voice Recognition Command. Not a good name for it, since it means 'a command by your nav system to say a command. Probably a bad translation from Japanese.Menu, Setup, go to page two, and turn it off. Then you will merely hear a "chirp", rather than the voice prompt. Thanks! I found it. Quote Link to comment Share on other sites More sharing options...
