TruSoljas69 Posted December 9, 2007 Share Posted December 9, 2007 2000 blk/blk GS400 ok, so i had a rough night, and swiped someones car, and broke my passenger side miror, i have the replacement i noticed there was a plastic trim going around the entire upper door, not a triangle i can just pop off and unscrew the old mirror so i removed all the screw from the door panel, and popped of the metal tweeter cover, but the door panel is still not trying to come out, it seems to be stuck where the window wedges are..... can someone help? Quote Link to comment Share on other sites More sharing options...
TRD911 Posted December 9, 2007 Share Posted December 9, 2007 2000 blk/blk GS400ok, so i had a rough night, and swiped someones car, and broke my passenger side miror, i have the replacement i noticed there was a plastic trim going around the entire upper door, not a triangle i can just pop off and unscrew the old mirror so i removed all the screw from the door panel, and popped of the metal tweeter cover, but the door panel is still not trying to come out, it seems to be stuck where the window wedges are..... can someone help? See the following.. this is the drivers side but it should be the same http://www.clublexus.com/forums/showthread.php?t=289839 Quote Link to comment Share on other sites More sharing options...
