Changing Tires
:chairshot: I'm probably stupid but i have a quick question. After removing the 5 bolt on the rear tire how to you take it off. Because I tried and the tire do not move at all. And the front ones were easy enough. Please i need your help.
I have a 98 GS300
Thank!
You may have corrosion locking the wheel flange to the hub. Take a large rubber hammer, or a piece of 4x4 fence post, and whack the outer sidewall of the tire inwards to tilt the flange. It should pop off quickly.
Usually what I do is put one lug nut back on a few threads, and give the sidewall a good kick. Most of the time this works. If not, bust out the big hammer. Just try not to hit the rim if it isn't rubber :rolleyes: Good luck.
