VJZ Posted November 24, 2007 Share Posted November 24, 2007 I took off the sensor directly to the left of the IDLE SPEED CONTROL sensor and now the TRAC light is on. To top that off when you hit the gas, it bogs down the engine such as if you had no traction. If you turn off the traction, everything is fine, but the TRAC light is on. What is the problem? Will this be costly for just taking off the sensor? Before taking it off everything was perfectly fine. Quote Link to comment Share on other sites More sharing options...
VJZ Posted November 24, 2007 Author Share Posted November 24, 2007 Actually it still does cut power with the traction turned off. Any ideas? Do i just have to drive it for 20 minutes or so to reset itself? Quote Link to comment Share on other sites More sharing options...
SCRider Posted November 30, 2007 Share Posted November 30, 2007 I think I might have the same problem. Please let me know how you fix yours. Quote Link to comment Share on other sites More sharing options...
