Panel Out Ls400 1994
hi, the ls 400 of a friend in france have a problem with his panel.
when the temp is 25 or 30° centigrade the car start and the panel is lightning correctly.
but if the temp is down 25 or 30°, the car start but the panel doesn't light !
Lexus dealer in france change neon's light and the condenser on the modul, but the panel is out. Something it flash.
i search in the forum but there is no good answer to this problem.
thanks to tell me.
Denis
thanks to tell me.
Denis
I had the same problem with a 94 LS 400. You are speaking of the instrument lights right? I found a guy in Canada that will repair the problem. You send him your cluster, it is easy to remove. He repairs it and sends it back. The cost was about $150 U.S. It fixed the problem and it worked great. His company name is Mr. Whizard. You can find him on the internet at www.mrwhizard.com . I would recomend him to all for this problem or any instrument cluster issue.
I hope this helps.
