Mass Air Flow Sensor
Piranha
i think i know what your problem is!just unhook your battery for about 2 minutes and reconnect it and the light should be out.im guessing you disconected the sensor when installing the air fiter.you should be fine if you just disconnect the battery and reconect it! :D
