LDR430 Posted November 1, 2007 Report Share Posted November 1, 2007 I got a flat tire about a month ago & thought nothing of it... change my back 2 tires & I should be fine, right? Wrong. After I replaced them, the car shook violently at 45-60 mph. I called Lexus & they said that it was a balancing problem since it only shook when I drove certain speeds. So I had it balanced & alligned. Then changed my front brakes... still shakes... not so violent anymore, but it still shakes nonetheless. Nobody knows what it is. I should probably mention that it's lowered with 20" wheels, but I've never had a problem before the flat. Any help??? Quote Link to comment Share on other sites More sharing options...
cardona6569 Posted November 2, 2007 Report Share Posted November 2, 2007 Regards: You need to have someone that is really good with tires check your tires, you could have a bad tire. Check the one that had the flat, and then check that rim to see if it did not hit anything or became bent somehow. CPR Quote Link to comment Share on other sites More sharing options...
