dgllexus Posted October 31, 2007 Share Posted October 31, 2007 i have a 93 sc400. my passenger door will not open from the outside. i tried to take the inside door panel off to see what it was, but couldnt figure out how to get it all the way off so i could only tell that something plugs into the inside of the door handle and i dont know what it is are there any diagrams or does anyone know how to fix this i hate paying people for something i can do. Thanks -DAVID Quote Link to comment Share on other sites More sharing options...
alslex Posted October 31, 2007 Share Posted October 31, 2007 i have a 93 sc400. my passenger door will not open from the outside. i tried to take the inside door panel off to see what it was, but couldnt figure out how to get it all the way off so i could only tell that something plugs into the inside of the door handle and i dont know what it is are there any diagrams or does anyone know how to fix this i hate paying people for something i can do. Thanks -DAVID I would suggest NOT to roll down the window. What usually happens is there is a small plastic clip on the outside handle that will break allowing the connecting rod to fall off. If you open the window it can catch this rod and bend and break it causing more problems. The good news is that if it is just the clip, it can be replaced pretty cheaply (only a couple bucks) if the rod breaks you could be into it for hundreds. To get the panel off there are 2 screws near the front of the door, 2 screws under the arm rest, about 4 screws across the bottom and 1 hidden under a removable plate under the inside door handle (this one got me the first time) Then just pull the panel off. Good luck. Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted November 2, 2007 Share Posted November 2, 2007 dgllexus, This is what you have to do for interior door panel take down to replace the broken piece. Click on links below http://clublexus.com/forums/showthread.php?t=109384 http://www.clublexus.com/forums/showthread.php?t=200819 http://northlandfasteners.biz/Store/advanc...dfrom=&dto= Part# N20469 Door Lock Rod Clip Right Side - Lexus & Toyota Quote Link to comment Share on other sites More sharing options...
