New Fog Light Idea
VJZ
I have been reading up on various ways to convert your 92-94 cornering lights to fog lights.
I realize that by doing the "conversion" on intellexual, you aren't actually making a fog light, just keeping the lights on.
On ebay, there are various fog lights that came out of the JDM Soarer and were imported through JHot and companies as such. According to Intellexual, the 95-96 fog lights won't fit the 92-94 bumper.
Will the JDM fog lights fit? If so, which ones (Links below)?
http://cgi.ebay.com/ebaymotors/JDM-Toyota-...1QQcmdZViewItem
or
or
udstuengt, The first link are fog lights that fit 95-96 models. The clear plastic a long with the wiring connections on the back of the casing have the same characteristic as the U.S. Sc 95 fog lights. I've got a 95 Sc and have change my fog light bulbs. I have encountered the same bulb casing and wire connections.
"I realize that by doing the "conversion" on intellexual, you aren't actually making a fog light, just keeping the lights on."
udstuengt, The Fog lights on my 95, only operate when the headlights are functioning. I think all Sc's fog lights (96-00) operate this way, you have no option.
"Is there an easy way to make any of these fit?"
You would have to modify, to make the 95 fog lights fit into your existing bumper. Another option is replacing your pre 95 bumper with a 95-00 front bumper and you still need to rewire. There is no easy solution at the moment to increase the bulb power on a pre 95 Sc.
As far as the other two JDM Fog Lights links, they don't have the right bulb socket connection a 12v H3 55w bulb. They are pre 95 corner lights.
