pishta Posted October 22, 2007 Share Posted October 22, 2007 Anyone ever pull a front fender on a 1st gen LS? Any tricks or suggestions> Like how do you pull the lower cladding off without breaking anything? I know there is 1 bolt under there. Also, how do you get to the outboard "city lights" sockets? I see them back there but dont know how to get these lights out. I see the top screw under the hood but is the other one way down between the light and the main light, accessible with a 12" long phillips? I need to remove the fender to pop a corner dent out or replace if unsuccessful. Thanks Quote Link to comment Share on other sites More sharing options...
2rotor Posted October 22, 2007 Share Posted October 22, 2007 You have to pull the fender lining out and then access the "pinch clips" for the chrome trim from inside the fender. It requires some needle nose pliers and a thin flat head. You pinch the plastic clips with the needle nose pliers and then pry the chrome trim off with the screwdriver. The rest removes itself. Quote Link to comment Share on other sites More sharing options...
