troner Posted October 21, 2007 Share Posted October 21, 2007 It may seem stupid but I need to know how to dismount the automatic shift knob. It has a plastic cover after the leather, I can see a screw but I can not remove this plastic cover. Please you help hopefully with pics. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
DClK Posted October 21, 2007 Share Posted October 21, 2007 don't know if this helps, i own a ls430 but... in my car, the whole knob (leather and trim) is spin on/spin off type. just like removing a screw out of wood, keep spinning to the left (counter-clockwise) until it spins off. might take a little extra muscle to get it moving but once you start it, it should be easy. took me a while to get up the nerve, but i noticed in some used car dealers pics that they took the knob off and you can see the threads on the shaft. i guess it's a theft deterrent thing for the dealers. adios, Quote Link to comment Share on other sites More sharing options...
sjc6765 Posted October 21, 2007 Share Posted October 21, 2007 Here you go. Will you take a pic of your heater VSV for me? sc400_94_gear_shift_removal_instructions.pdf Quote Link to comment Share on other sites More sharing options...
troner Posted October 22, 2007 Author Share Posted October 22, 2007 Here you go. Will you take a pic of your heater VSV for me? Thanks dude, I will take the picture for you tomorrow. Quote Link to comment Share on other sites More sharing options...
BadBob Posted October 28, 2007 Share Posted October 28, 2007 It may seem stupid but I need to know how to dismount the automatic shift knob. It has a plastic cover after the leather, I can see a screw but I can not remove this plastic cover. Please you help hopefully with pics.Thanks in advance. To remove the shift knob do this: 1) Set parking brake 2) Insert the key into the ignition and turn to on but do not start 3) step on brake and move shifter to a straight-up position (neutral or drive) 4) push the plastic cover below the shift knob down until the two screws holding the shift knob are exposed 5) remove the two screws with a phillips screwdriver 6) pull up on the shift knob to remove. Sorry, no pix. Quote Link to comment Share on other sites More sharing options...
