lexamainia Posted October 19, 2007 Share Posted October 19, 2007 hi fella's, i have a 92 ls400 with about 190km on my trany, recently i got this transmission code 63 which is offcourse #2 solenoid valve, i am gonna change that solenoid cauz as i believe and all you guys might agree its totaly worth it. but i am kinda confused about trans oil though sinse that trany has so many miles should i replace it with new trans oil or should i save the old one and reuse it? Quote Link to comment Share on other sites More sharing options...
SRK Posted October 19, 2007 Share Posted October 19, 2007 Once again the old myth about not changing automatic trans fluid on older transmissions rears it's ugly and misguided head. I don't know where that particular piece of lousy advice started, but it's a myth pure and simple. Toss the old fluid and install fresh Toyota Type IV and be done with it. Quote Link to comment Share on other sites More sharing options...
91LexusLS400 Posted October 19, 2007 Share Posted October 19, 2007 Also remember that you can change 2 quarts out every other oil change. The drain plug on the transmission pan will allow exactly 2 quarts to drain out to be replaced with 2 quarts fresh. This way you always have fresher fluid between a full blown drop the pan and filter change. Toyota Type IV only! Quote Link to comment Share on other sites More sharing options...
lexamainia Posted October 19, 2007 Author Share Posted October 19, 2007 thanx for the advise guys, i think i have made up my mind now to change it with new. will post how it turns out thanx again. Quote Link to comment Share on other sites More sharing options...
