1999 RX300
Today I experienced loss of cooling. ( outside temperature was 91 F.)
1. The compressor failer light did not flash on the "auto" button. So I think the compressor is ok.
2. The cooling came back on after being turned off for from 10 min. in one case to 1 hr. in the second.
and
the setting reduced temp to 65 F or "cold".
It came on and ran well for 45 min. until I parked it for the night.
I suspect it may have something to do with the "termostat" or computer.
Has anyone experienced this?
Roger
1999 RX300
and
Roger
If the engine coolant temperture raises above "normal" the A/C compressor will be automatically disabled.
Most commonly caused by a failed or intermittent radiator cooling fan.
1999 RX300
and
Roger
My temperature gage was about middle...and I think it is correct.
The problem occured when I started the car cold.
Then today twice, I used the car and the A/C came on.
Today... I had put it in AUTO and did not hit off and then hit the A/C button.
Monday I had been hitting the OFF button, then the A/C button and playing with the fan and temp settings.
  • 1 year later...
1999 RX300
and
Roger
Followup :
I had to have TWO computer boards Replaced !!!
( They tried the first, called me, then when I went to pick up the car they said they tested it
and their was still a problem and had to do the second.
o The instrument panel one which included A/C controls
o The primary computer for the Lexus RX300.
Hopes this helps someone.
