Slight Vibration At 1500 Rpm
larrytuttle
Just bought a used, certified, 2000 ES300 with 38,000 miles on it - with a 3 yr warranty. Very, very clean. However, after a few days of driving, I noticed a very slight vibration (through my hands on the steering wheel) that begins at about 1400 rpm and then goes completely away at above 1500 rpm. It happens only in gear, not in park or neutral. Its very slight but noticeable. Any ideas? Should I try to get this fixed under the warranty?
Larry, join the ES Idle Problem Club started my Amanda; I'm member #2 :lol::lol: j/k. I think my problem is a vacuum problem somewhere because when I open the hood and listen there is a hiss coming from somewhere. Plus, my tranny acts funny sometimes, and I think the vacuum leak is the culprit. You're lucky... I feel the vibrations even while in park plus at red lights. My vibration is only in the idle rpm range like 700-1800 rpms. Good luck!!!
