hondaspeed85 Posted September 29, 2007 Share Posted September 29, 2007 So I deleted my EGR (No i didnt buy the lextreme kit). But I followed directions I found on a different site. My question is, which plug do I put the resistor in? There are 2 plugs that go to the EGR, one toward the front of the engine (right next to the Diagnostics port), and 1 toward the back attached to the VSV. Also, the resistor is supposed to be a 10k Ohm 1/2 watt resistor correct? I put a resistor in the plug that was attached to the VSV, and the check engine light for the EGR came on a day later. I then put resistors in both plugs and the same thing, a day later the EGR code comes back up. Am I using the wrong resistor or something? Quote Link to comment Share on other sites More sharing options...
hondaspeed85 Posted September 29, 2007 Author Share Posted September 29, 2007 Nevermind I'm an idiot. It goes in the plug that is directly under the intake manifold where the EGR bolts to the manifold. :P I didnt even notice it when I deleted the EGR Quote Link to comment Share on other sites More sharing options...
