Keyless Programming
sramnari
:magic: I need help with programming my remote please. I've got a 99 lexus es 300 and recently got a denso remote FCC ID hyq1512p. Ive tried the following steps:
1) Driver door is open and unlocked, key is out the ignition.
2) Key is inserted into the ignition and removed without turning.
3) Using power lock, the door is locked and unlocked 5 times.
4) the door is closed and then opened.
5) Using power lock the door is closed and opened 5 times again.
6) key is inserted in ignition turned to on position and then off, key is then removed.
7) After the locks cycle,the lock and unlock button is held simultaneously for a second.
8) Immediately after the lock button is held for 2 seconds.
My problem is after step 6 when I hold down the lock/unlock button the locks cycle, but then when I hold down the lock button nothing happens.I appreciate any input.
let me guess.you had to turn the key more then once on and off right.i posted this in a earlier thread.i think its on off on off for programming.heres a few more in case you ever need them.
reprogram mode on off 2 times(witch you did to program the remote)
confirmation mode ignition switch on-off 3 times
erase mode on off 5 times
:D
  • 1 year later...
  • 10 months later...
:D
can you help me i have a 97 es300 and i bought a new remote and i can't program it i tryed two diffren programings but it still won't work
Hi, I bought a remote off ebay for my 01 ES and it hasn't arrived yet and I have a question.
I know these programming steps programs the remote, but does it also "verify" the remote key with the engine imobilizer system? Because I want to allow this remote key to not only unlock/lock the car, but also start the engine once I get it cut.
  • 9 months later...
Sit in the driver's seat and lock all the doors.
Unlock and open the driver's door.
Insert the key into the ignition and remove it (don't turn it...just remove it).
Using the MANUAL lock switch on the driver's door, lock and unlock the door 5 times.
Close the door.
Open the door.
Lock and unlock the driver's door 5 times (I'm almost certain you use the MANUAL lock switch again, but if this sequence fails to work, try again with the power switch).
Insert the key into the ignition and turn it to the "ON" position.
Remove the key.
The driver's door will now lock and unlock itself one time.
Press and hold the "LOCK" button on the key fob for at least 1 second.
Close the driver's door.
Open the driver's door.
Press and hold the "LOCK" button on the key fob for at least one second.
Press and hold the "LOCK" button on the key fob. The door will lock.
Press and hold the "LOCK" button on the key fob again. The door will unlock.
You should be all set.
