Remove Door Panel
Does anyone know how to remove driver's side interior door panel of 06 IS350?
You need to remove the screws holding the panel at the door handle after pulling off the cover plate. Then pull up the switch panel to remove. The door card/panel should then pull off. There are 3 or 4 long alignment pins that are prone to break if you are not carefull in pulling the panel off square, but don't worry if they do as they are just pins not clips and not essential.
Refit is reverse of removal.
Thanks!
  • 3 years later...
