Brake Caliper Replacement Pictures
VBdenny
Naw I originally made it in Powerpoint but that was 1.71MB which got kicked back by hotmail and others. I converted it to PDF and got it down to 583KB. I emailed Matthew McNully and he made the link. I just posted it cause I knew some of you wanted to check it out. I started doing that with all the stuff I do so when I go to do it again, I'll remember how. I could kick myself for not doing it when I replaced the headlight bulbs. I tried to remember and even went out and started taking one apart. Man, I just forgot how I did it. Anyway, it keeps me out of trouble!
  • 2 years later...
Thanks for the presentation.
I've been having a lot of problems replacing the rear driver's side caliper in my 99 ES 300. Between the caliper holding the pads so that they only connect with the edge of the rotor, and not being able to get pressure back it has been quite a struggle. Maybe your slide show will help.
Thanks
