needhelpwithbt Posted July 31, 2007 Posted July 31, 2007 I have a RX350 2007. I used to have a Treo 650 which worked fine with the bluetooth in the car. Now I have a 680 and the car won't recognize it, no matter what I do! Is there a new code other than 1111 that I can use to make it work? Any suggetions to fix this problem?
DArustik Posted August 3, 2007 Posted August 3, 2007 Although I am not sure...try 0000 as a code or 1234. Hope that helps
I_Heart_My_Lexus Posted August 3, 2007 Posted August 3, 2007 I have a Treo 700w and had the same problem... 0000 worked for me.
VroomVroom Posted August 13, 2007 Posted August 13, 2007 The code will be whatever is assigned in the car's bluetooth system. Where is the connection failing? I've seen Treos that are certainly tempermental - might be worth a soft reset of the phone before your next attempt.
