snjyzpilot Posted July 26, 2007 Posted July 26, 2007 Help please.... my 93 sc 400 just got a new fuel pump but that did not cure the stalling. I can hear the fuel pump shut off moments after start up. It does that a few times, then will run normally. Does anyone whats up with this car? thanx much, dan
snjyzpilot Posted July 27, 2007 Author Posted July 27, 2007 Fuel pump ecu, common on sc400's to fail. thanx, where is it located? does it require a dealer? is that the proper name of the part when i ask for it. thanx very much, dan
mehullica Posted July 27, 2007 Posted July 27, 2007 It's in the LH quarter panel trim. Under the window. You'll have to take out the back seat and drivers seat belt to get the panel off. It's called a fuel pump ecu, the dealer should have no problem getting you a part.
