Sc300 Transmission Fluid Recommendations
JDOwen2
For the SC300, stick with the Dexron family. That's what is recommended, that's what you should use. If you're talking about different types of Dexron ATF... I've used the Mobil 1 synthetic ATF and Valvoline MaxLife dino oil ATF. Both are Dexron II/III compatible oils. It seems to shift a little bit smoother with the Valvoline. I've been using their MaxLife motor oil and the valve sounds seem to have diminished a bit also. Change your tranny oil often...
