Sign in to follow this
xsanix
Es 300 Brakes ?
    :magic:  i am a new buyer of Es 300 97. I was wandering if n e one can tell me tht is it n e different then n e cars in matter of changing brakes. I have changed brakes of other cars as toyotas andd hondas my self. But since its a lexus so a little hesitant . is it different then n e other car ? shall mess with it or take it to lexus dealer ? thank u guys.
      Cheers. Sani
Share this post
Link to post
If you have changed brake pads before, then yes, it is pretty much the same as others. The brake line is held in place by a nut, which you should loosen to make it easier to move the caliper. After that, just use a c-clamp to compress the piston back down (check that the brake fluid reservoir doesn't overflow, I have heard that the stuff is pretty corrosive).
I didn't re-adjust the parking brake though.
Let us know how it turned out :cheers:
Share this post
Link to post
Loading...
