aamir007 Posted June 18, 2007 Share Posted June 18, 2007 I have a 1993; Lexus, LS400 and a mechanic removed the w/Trac-Sub throttle Actuator Connector by mistake and broke the connector. Now all 6 pins are loose and he doesn't know the sequences it will connect again. He connected by guessing it but car will shut down after a while and wouldn't start again till it cool down. Can some one tell me the correct combination of six pins or 3 pins on each side? You can look at your 93, LS400 and tell me. Also tell me where to buy the connector as I can't afford the whole harness? 1993 Lexus LS400 Thanks for your help! Quote Link to comment Share on other sites More sharing options...
termin8or Posted July 22, 2007 Share Posted July 22, 2007 I have a 1993; Lexus, LS400 and a mechanic removed the w/Trac-Sub throttle Actuator Connector by mistake and broke the connector. Now all 6 pins are loose and he doesn't know the sequences it will connect again. He connected by guessing it but car will shut down after a while and wouldn't start again till it cool down. Can some one tell me the correct combination of six pins or 3 pins on each side? You can look at your 93, LS400 and tell me. Also tell me where to buy the connector as I can't afford the whole harness? 1993 Lexus LS400 Thanks for your help! I would go to a junk yard and cut off and re-soder the wires to your car. I just saw one of those connectors at a local IL junk yard. Quote Link to comment Share on other sites More sharing options...
