Davidliang Posted June 18, 2007 Report Share Posted June 18, 2007 Dear all My Ls400 have a small click noise come out from the left side of dash board recentally, the click frequency depend on speed; when the car run fast then the click sound go fast, it just like a speed wire thing drive a meter thing, but the sound is loud enought that you can heard it. Is there anything loose or wearn? how to fix it? Thank in advance David Liang Quote Link to comment Share on other sites More sharing options...
flanker271 Posted June 18, 2007 Report Share Posted June 18, 2007 Is your odometer working? Quote Link to comment Share on other sites More sharing options...
Davidliang Posted June 19, 2007 Author Report Share Posted June 19, 2007 Thank! Did you mean the right down side of dash board mechanic meter which show total milage? thats seem working fine, you think it will break need to repair or just loose need to connect tight ? is this a ordinary fail for Ls400? my milage show about 110,000 only. Quote Link to comment Share on other sites More sharing options...
flanker271 Posted June 19, 2007 Report Share Posted June 19, 2007 Yes that's the meter I'm talking about. My odometer failed at 110,000 miles exactly and it is also making a faint ticking sound from the dash at that time. I think it's coming from the spinning cable feeding the worm gear for the odometer. After about 100 miles of driving the noise went away. My guess is that one of the gear teeth is stripped and the gear struggled to turn. Eventually a catastrophic failure caused it to disengage from the driving cable permanently and the sound went away. About 2 years ago I also started a similiar thread regarding this ticking noise. It has much detailed information including some pictures, but I can't find that thread. Can someone dig up that URL? Quote Link to comment Share on other sites More sharing options...
Davidliang Posted June 19, 2007 Author Report Share Posted June 19, 2007 Thanks flanker271 I believe i have the same problem as you did; I found the thread you mention, I will look into it. http://us.lexusownersclub.com/forums/index...c=15656&hl= Quote Link to comment Share on other sites More sharing options...
