G M E Posted June 16, 2007 Report Share Posted June 16, 2007 All four screws are removed, but clusted will not pull out enough to reach/unplug the cables? Any help you may provide would be greatlly appreciated. Quote Link to comment Share on other sites More sharing options...
ruey220 Posted January 25, 2009 Report Share Posted January 25, 2009 All four screws are removed, but clusted will not pull out enough to reach/unplug the cables?Any help you may provide would be greatlly appreciated. any luck? Quote Link to comment Share on other sites More sharing options...
tang.33 Posted January 14, 2010 Report Share Posted January 14, 2010 All four screws are removed, but clusted will not pull out enough to reach/unplug the cables?Any help you may provide would be greatlly appreciated. There are two more screws you need to remove(loosen). They are located on the bottom of the cluster next to the botom two you removed. Then you should ba able to pull it out. There is a PDF online. 11. REMOVE COMBINATION METER (a) Disconnect the connectors. HINT: The connectors can be disconnected by loosening the bolts. (B) Remove the 2 screws and bolts. © Using a screwdriver, remove the combination meter. HINT: Tape the screwdriver tip before use. Quote Link to comment Share on other sites More sharing options...
